I am getting ready to do a rebuild/upgrade for a family member and I found out their power supply is unreliable, therefore I need some advice on how big a PSU I should install when I rebuild their system.
Here is the current hardware that is going into the system
AMD A6 Llano 3500
Gigabyte A55M-DS2
Vengeance CMZ8GX3M2A1600C8R
I will be reusing their small (160 Gb) hard drive as well as their optical drives, 1 old CD ROM and 1 DVD burner
the current one is an old HP with a Video recorder / FM tuner card that I will probably re-use as well.
I want to make sure I have enough overhead that is they decide to add in a second HDD or even a lower end video card that I will have the power to run them.
Thanks in advance for any advice all of you give me.
AMD A6 Llano 3500
Gigabyte A55M-DS2
