hi i am charlie!
I am 16 and am going to try to build a pc. Do you think it is worth it is worth it for me to try to build my own pc?
My other task which would be awesome for you guys to do is that i am going to have a 700 dollar budget. I would like all parts excluding a case, mouse, keyboard, and monitor.
I already have a case so the whole $700 is into the parts excluding the case! Some requirements follow...
A 1tb hard drive, a quad core cpu or better, 8 gb of RAM, and a cd and dvd drive and if possible a blueray drive as well.
Thanks for all help and i really appreciate all effort you give!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517004
