I have read many reviews on the 7970 saying that it ran at 40% fan speed + @ 73deg C and after purchasing one am wondering if it is normal for my card to be running @ 90deg C with 55% fan speed just because its installed in a case not an open test bench and the ambient temp of the room is 24deg C instead of 22.5.
I have http://www.newegg.com/Product/Product.aspx?Item=N82E16811352018 case and http://www.newegg.com/Product/Product.aspx?Item=N82E16835106133 fan installed in it as a intake. all case fans are also running @ 100% speed as they are still silent with that speed.
It is quite loud even after installed in that noise dampening case so if this is not normal i would like to return it for one that doesn't run as hot..
