Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > [Solved] GPU cooling with side panel case fans, whats better Exhaust or Intake?
Forum Graphics & Displays : Graphics Cards [Solved] GPU cooling with side panel case fans, whats better Exhaust or Intake?
Best answer from purple stank.
To cool down a GPU with a side panel case fan is it better for the fan to be an Intake or an Exhaust? Theres actually room for 2 fans what if I got 1 intake and 1 exhaust would that be a good idea?
Reply to vistavendetta
Well Intake, cause heat rises right? Push air onto the GPU with the side panel fans, and then the heat rises and get sucked out by the rear (and a possible top) fan.
And your last bit there with one intake and one exhaust, that would just basically cancel them eachouter out, cause I reckon that the exhaust fan would be pushing out about 40% of the air taken in by the intake fan!
Message edited by LtnCharles on 02-04-2012 at 08:49:47 PM
Reply to LtnCharles
No it wouldn't be cause that would create negative airflow.Can't have a intake and exhaust so close to each other.
I have my side fans as intake,blowing cool air over the card.I think doing this will force most of the air out the back of the case through the card.Also adding cool fresh air for the GPU fan to use.
Reply to purple stank
Back and Top = exhaust
Front and case window = intake
------------------------------ If a man speaks in the forest and no woman hears him, is he still wrong ?
Reply to JackNaylorPE
Intake is much better for side fans , blowing cool air onto your cards and creating a positive airflow through your case is optimal for cooling, as purple stank said it will force most of the air out the back of your case.
------------------------------ i7 3770K OC, CORSAIR VENGENCE DDR3 16GB,EVGA GTX 680 SC,ASUS SABERTOOTH Z77,CORSAIR FORCE 3 SSD,SB TITANIUM HD,ENERMAX REVOLUTION 1050W PSU,THERMALTAKE ARMOUR LCS,SAMSUNG SYNCMASTER 27.5
Reply to monsta
Okay so if I add an intake side panel fan, 120mm coolermaster fan with an air filter, how much of a drop in temperature of the GPU should I expect to see?
Best answer
Most Coolermaster 120mm fans have very low CFM and with a dust filter it will be even less.
Honestly I didn't notice any difference in temps on my GPU with 2 side fans for intake.Maybe 1c at most.The biggest thing though is of course cooling the GPU itself but also to cool everything else on the PCB.I'm sure having fans pointed at the card will increase airflow around the VRM's and RAM chips.
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1528 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 3 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
