Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > [Solved] Display offset two inches to the right
Forum Graphics & Displays : AMD Radeon [Solved] Display offset two inches to the right
Best answer from rolli59.
Hello, I have spent some time seaching for the answer to no avail. I have a HIS Radeon 6870HD graghics card and an old dell monitor that has been functioning just fine until I found my computer in this state today after my wife powered up the computer this morning. I have tried to use the monitors shift to the left to get the screen centered to. It doesn't go far enough. Everything is there but just offset. Any ideas as to what is happening and how I get it back to the way it should be?
Reply to BrianBuan
Best answer
Have you tried adjusting using in CCC? If that does not work most likely it is the screen going out.
Reply to rolli59
Ok CCC? Not following. What is CCC?
Reply to BrianBuan
Ok Catalyst Control Center it worked.
Reply to BrianBuan
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1518 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 3 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
