Power Supply Failure, need help with finding a new one
Last response: in Components
- SolvedMy power supply has been making a crackling noise. Need help finding a new one. Forum
- SolvedI need help on finding a new power supply for my new gtx 770. Thanks. Forum
- Power supply failure, Need advice on a new one Forum
- Help finding 3.5 enclosure w/ big power supply (do I need one?) Forum
- SolvedNeed help with finding the best power supply and RAM Forum
- SolvedI need help with finding a power supply... Forum
- SolvedNeed help finding a power supply Forum
- SolvedNeed Help finding the wattage on my power supply. Forum
- am2+ motherboard died need help finding a new one Forum
- SolvedNeed help finding a power supply... Forum
- SolvedNeed help finding a Decent power supply Forum
- SolvedGraphics card dying, need help finding a new one. Forum
- Graphics card is fried and I need help finding a new one Forum
- SolvedNeed some input on new build power supply choice because one I bought came DOA :( Forum
- SolvedNeed help finding right size power supplies Forum
- SolvedI need help to choose one Power Supply Forum
- need help finding memory, cpu cooler, power supply, and case for my build Forum
- New to laptops need help finding one that fits my needs. Forum
- More resources
Read discussions in other Components categories
... So I researched quite a bit on what to do, followed all the advice, and still wasn't doing the trick.. So I finally got too frustrated with the thing and called up one of the local computer companies to come check it out. He found the problem and said that I didn't have the CPU fan seated right and that was probably my only problem right there, and that it was important to place my motherboard on standoffs, so he placed the standoffs for me and left me to putting in the motherboard myself(because I've done it before) and then he left, he also advised me that it wouldn't be a bad idea to put the PCI-E cord from my power supply and put it in my other ATX power slot on my motherboard(I have 2 slots for ATX power).. So he leaves and says that it should boot now that the CPU fan is seated correctly, I screw on the motherboard, and try to put that PCI-E cord into the other ATX slot(I know PCI-E is for graphics cards, but he said it should work), and then when I tried to plug it in, it did not fit right and i just left the cord in there even though it didn't fill the whole slot thinking it wouldn't do anything. So I plug in the main power to the mother board, place both the RAM sticks in the right place, plug in the front panel connections , plug in the ATX CPU slot and the PCI-E cord to the GPU. Then I flip the switch, press the power switch, and nothing happens... 5 seconds later the power supply starts sparking and smelling. So I know the power supply that costed me $115 is done for.. So I believe the power supply failure was due to either a half way plugged in PCI-E cord into a ATX slot. Or could have been that I had 2 stand offs screw things missing(but the guy said it should be fine). So anyways, can anyone tell me if they think those 2 things could have caused it, and does anyone have some advice on what new power supply I should invest in now?
