Solved
Case Airflow Advice
Last response: in Components
Hey everyone,
I have a Cooler Master HAF XM case and I was wondering what advice you would give as far as airflow through the system. (eg. Front - air into case, Top - air out of case, etc.)
There is a 200mm fan on the front, 200mm fan on top, and a 140mm on the back. I can add another 200mm on top and a 200mm on the side of the case. Cooler Master HAF XM Cooling
I'll only be running one EVGA 670 FTW and i5-3570k with Hyper 212 Evo.
More about : case airflow advice
Power supply Master
front and side - intake
top and rear - exhaust
frankly the stock fans in your case provide plenty of airflow and the extra fans added may do more harm in interrupting airflow then helping in cooling
rolli59 said:
Front in, top and back out. It is not necessary to add a side fan but if you do it goes in.
I was told that front in and then side, top, back all out.... I didn't notice a difference in temperature when I switched it from pulling in to pushing out.
Related ressources
Anonymous
Power supply Authority
anything above the top of the cpu goes OUT
anything below the top of the cpu comes IN.
the heatsink direction is usually to towards the back but it there are fans on top then either direction works.
Did a little research and it seems that, for the Hyper 212 EVO, I would need to mount it horizontally, with the fan blowing out the top. The fan is a sleeve bearing and according to Anatomy of Computer Fans, sleeve bearings wear out faster if the fan is mounted vertically, with the fan blowing out the back.
Thanks everyone for the great feedback! I really appreciate it!
Ask the community
