Solved
Building My first Gaming PC $800 please help
Approximate Purchase Date: asap, within a week or so
Budget Range: $800.00
System Usage from Most to Least Important: Gaming (Diablo 3), other games, web surfing, word processing.
Parts Not Required: Monitor (I just bought an ASUS VH236H Black 23" 2ms Full HD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
Preferred Website(s) for Parts: anywhere most bang for my buck im new at this.
Country: U.S.A.
Parts Preferences: NONE
Overclocking: IDK what this is.
SLI or Crossfire: IDK what this means either.
Monitor Resolution:whatever is best for gaming and the monitor listed above (ASUS VH236H Black 23" 2ms Full HD)
Additional Comments: I need everything i have nothing to start with. i need cables, Operating system etc.
Thanks in advance!
7 answers Last reply Best Answer
More about building gaming help
  1. A little bit over budget but here you go:
    Case: Cooler Master HAF 912 - $59.99
    PSU: Seasonic M12 II 620W - $89.99
    Motherboard: Asrock Z68 Extreme 3 Gen 3 - $121.99
    CPU: 3.3Ghz Intel Core i3-2120 - $127.99
    RAM: 8GB G.Skill Ripjaw X 1600Mhz 1.5V - $46.99
    HD: Seagate / Samsung Spinpoint F3 500G - $79.99
    Optical: Lite On Bulk DVD Burner - $17.99
    Video Card: Sapphire Radeon HD 7850 - $259.99
    OS: Windows 7 Home Premium - $99.99
    Total: $894.91 ($794.91 without OS)
  2. Best answer
    Overclocking is boosting the capabilities of your CPU and GPU, it DOES produce heat and doing it not correctly will destroy your system.
    Crossfire and SLI is where you have 2 GPU's basically one rendering a frame and then the other GPU rendering another.
    Your monitor is running at a max of 1920x1080
    Heres my thoughts on a build:
    AMD Phenom II X4 975BE w/ Team Xtreem RAM $177
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.880742
    (Good budget CPU and nice budget RAM)
    Gigabyte 7850 $250
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125419
    (Look up how to overclock and this thing will be as good as its $350 brother the 7870)
    ASRock Extreme4 Mobo $110
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157262
    (Good mobo for the price, can run crossfire in the future with a PCU upgrade)
    Disc Drive $22
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106378
    Rosewill Case and 630 Rosewill PSU $105
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.867690
    Refurbished WD Caviar Blue HDD $43
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136577
    Windsows 7 Home Premium 64 Bit OEM $100
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
    Total $807
  3. thank you so much! so if i buy everything you listed i can make the whole computer?
    which item is the video card?
    Refurbished WD Caviar Blue HDD is ok refurbished?
    and this should run diablo 3 on max settings?
    Windows® Vista/7 (latest service packs)
    Intel® Core 2 Duo 2.4 GHz or AMD Athlon™ 64 X2 5600+ 2.8 GHz
    2 GB RAM
    NVIDIA® GeForce® 260 or ATI Radeon™ HD 4870 or better
  4. Quote:
    Refurb is *NEVER* Ok - sure it's discounted but there's no support for it.
    2 GB RAM
    That's just the bare minimum requirements - what you barely need to play D3. The system I posted will be able to run it on high or ultra high.
  5. you watch many youtube videos on making pc first do that before but its not that hard and id go with the fx 6100 and 990fx motherboaRD i like amd
  6. Best answer selected by Mikewar123.
    i ment to flag this as best answer sorry!! :( but thanks so much for your help ordering this build tonight!
New Build Gaming Monitors Systems Product
