Power choice for new build with possible new video card
New build -
i5-2400
ASRock Z68 PRO3 GEN3 LGA 1155 Intel Z68
G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
Mushkin 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
ASUS 24X DVD Burner
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=19931046
I'd like to use my current video card until the other Nvidia 600s come out.
Current Video Card: EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130434
Here is my dilemma, do I get a new PSU or use an extra one I have? If the old PSU isn't going to be enough for a new video card then I will probably just upgrade. Just hard to tell when I don't know what video card I may get. I guess the GTX 680 would be the most, but I expect something along the lines of the GTX 560TI(600 series version though).
Extra PSU: CORSAIR HX Series CMPSU-520HX 520W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
New PSU: CORSAIR Enthusiast Series TX650 V2 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
I am having trouble waiting for the new video cards to drop and may just go with GTX 560TI.
1 answer Last reply
More about power choice build video card
  1. New generation graphics cards use less power .
    Wait till you know the power requirements of your new graphics card and decide then
New Build Graphics Cards New Build Systems Product
