I am wanting to overclock (modestly) an i7-3770K, on an Asus P8z77-V PRO mobo. Am thinking of using Corsair H80 closed loop liquid cooler, but am unsure of the best means to control it. Corsair's "stock" method is to plug 3 pin connector to mobo's 4 pin CPU cooler header. They also provide a molex connector, to connect to PSU. (confess I'm not sure if that's a case of both, or either). Presumably, this way, radiator fan speed is contolled by coolant temp. There is a manual selector on unit, but understand that sets "max".
I have also seen a suggested alternative, where it's the radiator fans, themselves, that are wired directly to mobo CPU cooler header, presumably with pump wired directly from PSU. I take it, this way, fans are controlled, directly, by CPU conditions. Is this option "workable", and, if so, is it actually BETTER?
Please forgive what is probably a beginner's question, but, as it's my first self build, I am!
Many thanks.
Many thanks.
