Archived from groups: rec.photo.digital (More info?)
I have a Nikon D70 + SB600 flash. A very serious problem is that either with
the build in flash or the SB600, the preflash that is used to TTL calculate
the power of the main flash is well separated from the main flash about
20-30 msec. So every time you can see two distinguished flashes. Some very
sensitive people can close their eyes after the first flash, so when the
main flash lights, they have eyes closed. This effect in a wedding for
example can be a disaster, as 90% of the shoots finds the bride with the
eyes closed.
I have test a Canon 20D + 550EX flash and the preflash was so close to the
main flash so subjectively we could see only one flash. This means less than
10 msec. No one could close his eyes so fast, so there was no problem.
My question is: Is a specific problem to the build in and SB600 flashes, or
is general in Nikon iTTL; It is the same with SB800; What are your
experiences;
Dimitris M
"Dimitris M" <nospam@ath.forthnet.gr> skrev i meddelandet
news:1119222321.762661@athnrd02...
>with
> calculate
> eyes closed.
> than
> or
> experiences;
> Dimitris M
Here you can learn more about NIKON D70 and flash.
<http://www.mir.com.my/rb/photography/companies/nikon/htmls/models/digitalSLRs/D70/index.htm>
Not all functions are avilable with SB600 better go for SB80DX.
"Dimitris M" <nospam@ath.forthnet.gr> writes:
> experiences;
There is a short lag with the SB800. Not long enough to cause eyeblinks
as far as I know. I do get eyeblinks with the Canon S100 point-and-shoot.
I seem to remember with the SB800 (and probably also SB600) there is a way
to pre-meter the flash exposure, so there's no preflash needed.
On 19 Jun 2005 17:25:29 -0700, Paul Rubin
>> experiences;
The lag between preflash and flash with the SB800 is easily
perceptible, so probably it is the same as with the SB600 (which I
don't have and cannot compare with directly). Even more with commander
mode, which issues several perceptible preflashes to exchange data
wirelessly between flash units.
>eyes closed.
It doesn't seem all that likely to me that a 30 msec lag is enough to
cause a blink which disturbs the picture. When a blink response is
elicited by a flash, and measured by the EMG signal (not even the
moving eyelid) the latency seems to be around 55 msec in adults.
The blink itself takes 200 msec to complete, so eyes closed would be
100 msec or so after the flash as I make it.
The "startle reflex" seems to be faster for acoustic stimulus than
flash. Given that the mirror moves and the shutter opens well in
advance of the flash, perhaps it's a case of the person reacting
to the sound of the camera in anticipation of the flash? Maybe
some cameras are better or worse at that.
>experiences;
Ken Tough <ken@objectech.co.uk> writes:
I see this problem happen with my Canon S100 which has no moving
mirror and a very quiet shutter, although the two flashes are maybe
more than 50 msec apart. However, I never saw it happen with any
regularity using film SLR's with no preflash.
To the OP: Try using the FV Lock setting to suppress the preflash and
see if you still get closed eyes. You will have to take a test flash
to set the initial exposure, but after that, FV Lock re-uses the same
exposure for further shots instead of measuring again with a preflash.
No, the SB80DX doesn't work with iTTL, and the D70 doesn't do DTTL.
Avoid this combination.
In case you meant the SB800, it has the same problem with the preflash
as the SB600.
This problem is real, I'm seeing it too and I know many other people
that experienced it too.
> experiences;
I noticed the same problem. I see three solutions:
Use FV lock to trigger the preflash well before the main flash. This
works, but it is a daunting to use. Also, the metering in the camera is
different. I think it switches to center-weighted metering, but I'm not
completely sure. I couldn't find it in the manual. On some pictures the
exposure is off due to this.
Disable the preflash. Switch the flash to "A" mode (not "AA", there is
still a preflash). It is in the custom setting of the SB800, maybe the
SB600 doesn't have it. This works well, but you have to set the
aperture, ISO value and zoom manually on the flash. I don't know why
there is still a preflash in the AA mode, I see no reason for it.
Use GN mode (SB800 only). This is manual mode without preflash. You have
to dial in the subject distance on the flash which is easy and quick,
everything else gets transmitted automatically.
On Mon, 20 Jun 2005 02:06:30 +0300, "Dimitris M" <nospam@ath.forthnet.gr>
>eyes closed.
>experiences;
I've not yet got either an 800/600 (I'm thinking about it, so I'm prowling
threads about them) but:
Presumably the flash is being held to one side, as presumably the D70
wouldn't have to issue command-flashes to SB600/800 if it was mounted on
the hot-shoe?
Although less convenient than the "wireless" mode the D70/SB600/800 use,
could you connect a shoe-extension code (I assume they exist) between the
two, and would this stop the communication pre-flashes?
Regards,
Graham Holden (g-holden AT dircon DOT co DOT uk)
There are 10 types of people in the world;
those that understand binary and those that don't.
On Tue, 21 Jun 2005 14:02:03 +0100, Graham Holden
>the hot-shoe?
Correct. If the SB800/SB600 is mounted on the camera's hot shoe, there
is no need to use commander mode (unless you want to control other
off-camera flash units)
If you mean a SC-28 cable, correct. With the SC-28, the camera thinks
that the flash is mounted on the camera's hot shoe (in fact it is, in
the sense of electrical connections).
Just remember that you must set commander mode or normal mode manually
on both the camera and the flash unit. If you set the camera in
command mode, a hot shoe mounted SB800/SB600 (or the built-in camera
flash) _will_ issue command preflashes. The camera manual also tells
you which command group settings to use on a remote flash if you use
the built-in flash as commander.
