popatim said:
Which way is the Zalman pushin air? It should be up (into the bottom of the PSU) or rearwards (towards the rear 120mm (which should be blowing air out of the case))
Do you have the zalman set on high speed ?
as for the pcie slot cooler. it looks like the rear fan (the orange one in the pic) is blowing air out of the case. If its mounted lower than the gpu turn that fan off, you're pushing cool air out of the case. Use the directional fan to blow air towards the gpu fan.
That case is not a great case for overclocking builds as there is not enough airflow. heck its probably not enough for a good gaming rig period. It needs a bigger fron intake fan or two and at least a spot to mount a 120mm side fan.
If heat issues still persist, remove the side cover and point a fan to the interior .
The HSF is pointed toward the 120mm exhaust to blow air out, and it is set to high speed.
Thanks for the tip about the PCIe fan, I wasn't really sure of the best way to configure it and when I first put it in it didn't seem to do much to help my temps.
I figured the case isn't the best for airflow, but here's the thing:
Back when I built this rig 2 years ago, my idle temps were right around 30 on stock HSF, stock thermal grease, and stock clocks/volts. I was even running a GTS 250 at that time, which ran much hotter than my current 7850. When I got my Zalman and AS5, I didn't really see any further drop in temps, and over time it seems to run hotter and hotter.
I turned the CPU down to 3.2 GHz and 1.35v and I get 41 idle and 62 load. I feel like it has to be the thermal grease at this point because I don't see any other way to explain such a rise in temps compared to when I first built it. The stock HSF came with a peel-off layer of thermal grease which made application much easier for me, especially since I had never done it myself before.
I'd be more inclined to believe it's a problem with my case if I hadn't already witnessed much cooler temps. I'll try reapplying again this weekend and this time I'll be sure not to lift the HSF from the CPU at all.
(edited for clarity)
