Power supply
Last response: in Components
Power supply Master
For a system using two GeForce GTX 560 Ti graphics cards in 2-way SLI mode NVIDIA specifies a minimum of a 700 Watt or greater power supply that has a combined +12 Volt continuous current rating of 50 Amps or greater and that has at least four 6-pin PCI Express supplementary power connectors.So since your only running one you would be fine with something like this XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E168... or the above mentioned seasonic
Related ressources
oh ok sweet! thank you!!
im kinda a noob at this so i have another question... my mobo says RAM ddr3 2400mhz and my ram cards say 1333mhz what exactly does that mean?
i have 2 @ 4Gbt ram at 1333mhz
Ask the community
