Edited for template:
Approximate Purchase Date: This week
Budget Range: Around $1300
System Usage from Most to Least Important: Gaming, internet.
Parts Not Required: Keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: Newegg
Country: USA
Parts Preferences: N/A
Overclocking: No
SLI or Crossfire: N/A
Monitor Resolution: Current monitor is 1600x900
Additional Comments: The aim is to have a build that can run games at smooth frames, I am not concerned with having graphic settings set to ultra-max on everything in every single game.
EVGA GTX 570 HD 2560mb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130687
GSKILL ripjaw 8gb ddr3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
i5-2500k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
COOLERMASTER silent pro 1000w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171049
Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128545
NZXT Phantom White steel ATX full tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
Country: USA
Overclocking: No
i5-2500k
