Heat problem?
Hello!
I have a AMD Phenom ii x4 965Be, when i'm playing games the temp varies.
My Minecraft CPU Temp is: 59c
My Dirt 3 CPU Temp is: 63c
I heard people saying that 60 below is the max core temp?
I also have stock cooler.
I also am using Arctic Silver 5.
20 answers Last reply
More about heat problem
  1. Who said that?
    The max core temp (tcase) is around 70-110oC depending on what CPU you have got.
    Your load temps are fine, especially with a stock cooler.
    People say that 60oC or around 65oC is good, 50-60 is better, anythink below excellent for heavy load temps.
  2. A seen it on a couple of forums. So me getting 65 or less is ok?
  3. jay_nar2012 said:
    Who said that?
    Read the second comment.
    http://www.tomshardware.co.uk/forum/329458-10-phenom-maximum-temperature
  4. 62oC is a little 'low' for a max temp unless AMD are being careful?
    Maybe thats the danger area, according to this site, the critical area is 62-71oC- AMD Phenom ii x4 965Be
    But if you are scared of damaging your CPU then you could buy a aftermarket heatsink like this- http://www.amazon.com/Cooler-Master-RR-910-HTX3-G1-130-Watt-Hyper/dp/B0028Y4S9K/ref=pd_cp_e_2
  5. jay_nar2012 said:
    What about this: http://www.amazon.co.uk/Cooler-Master-Hyper-212-Plus/dp/B002G1YPH0/ref=sr_1_2?ie=UTF8&qid=1343170672&sr=8-2
    Also if i get an after market CPU will i need to upgrade my PSU? It's 550w now. With gtx 560
  6. That one would be fine.
    No, you won't need to upgrade your PSU, you only need to power the fan.
  7. Thanks! :)
  8. Your welcome!
  9. And don't forget to clean your CPU.
    I just got the Artic silver paste yesterday. I apllied it today. Cleaned the cpu and now i'm getting 2c less than i was with the old one..
  11. 2oC is not much, according to the reviews of the heatsink, overclocked i7s reached 39oC max......
    Well i'll buy the Evo plus and see how it goes form there.
    Here is a screen shot of my CPU settings while playing Minecraft!
    http://gyazo.com/fce15b0f81418d220821bd1de8b6819f
    Is everything fine? I just had closed minecraft that is why the temp has dropped a bit.
  14. You temps have improved, they are good temps, you are in the 'safe zone'.
    It was 57c. is the voltage right and all that stuff?
  16. The voltages are fine, looks like your fan is spinning fast..
    Good or bad? 5500rpm sometimes
  18. Probably a good thing, trying to cool your CPU down.
    Stock heatsinks are small.....
  19. The termination temprature in Phenom ii is arround 101 c.
    You have really good temps for a stock cooler is sure you will do much better with an aftermarket.
CPUs
