My first home build - advice please
Hi -
Would appreciate expert advice on the compatibility / overall thinking behind this setup. Hoping to order / build within the next 2-3 weeks.
Thanks!
Case £130 Cooler Master HAF X Ebuyer
CPU £220 Intel i7 2600K Amazon
Cooler £40 Zalman CNPS9900-MAX Amazon
Motherboard £140 ASUS P8Z68-V PRO/GEN3 Amazon
PSU £70 OCZ Technology 700W MODXSTREAM PRO Amazon
HDD (SS) £110 Crucial CT128M4SSD2 128GB SSD Amazon
HDD (Spindle) £90 Seagate ST2000DL003 Barracuda 2TB SATA 6 Gb/s Drive (64MB Buffer,5900RPM) Amazon
Memory £40 Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit Amazon
GPU £185 Saphire HD 7850 Dabs
Optical £15 Sony DVD-R Amazon
4 answers Last reply
More about home build advice please
  1. Sorry - should have stated: UK build, budget c.£1K.
    OS already owned.
  2. Check right before you order if IB and Z77 is out where you're buying. You may want a 7200rpm HDD... it's better. That RAM is very expensive. Also, an i5-2500k will suit gaming needs perfectly... any higher is really impractical.
    If you used the format stickied at the top of this subforum, we'd be able to help you out more.
  3. That OCZ 700w isn't one to be recommended. That particular line of OCZ psu's are manufactured by Sirtec for OCZ and they are pretty much junk. Here's some idea's to look at.
    Ivy Bridge cpu's are due out April 29th.
    http://www.amazon.co.uk/Corsair-Carbide-Series-Mid-Tower-Gaming/dp/B005E983JW/ref=sr_1_5?s=computers&ie=UTF8&qid=1334440692&sr=1-5 £97.60
    Corsair Carbide Series 500R Mid-Tower Gaming Case (Black)
    http://www.corsair.com/pc-cases/carbide-series-pc-case/carbide-series-500r-mid-tower-case.html <----- A better look at that case
    http://www.aria.co.uk/Products/Components/Power+Supplies+-+PSUs/Non-Modular+700-950W/750W+OCZ+ZS+Series+80PLUS+Bronze+Power+Supply+?productId=45459 £62.39 inc. VAT
    750W OCZ ZS Series 80PLUS Bronze Power Supply
    or...
    http://www.amazon.co.uk/OCZ-Series-Power-Supply-OCZ-ZS750W-EU/dp/B005DCBR1G/ref=sr_1_4?s=computers&ie=UTF8&qid=1334440826&sr=1-4 £70.24
    OCZ ZS Series 750 W PC Power Supply (OCZ-ZS750W-EU)
    http://www.novatech.co.uk/products/components/motherboards/intel1155z77chipsetmotherboards/ga-z77x-d3h.html £109.99 inc vat Free Delivery
    GIGABYTE GA-Z77X-D3H Intel Z77 (Socket 1155) Motherboard
    http://pcper.com/news/Processors/Intel-Ivy-Bridge-Processors-Launch-March-23-2012 £167.99
    (inc. VAT)
    Intel i5-3750K Ivy Bridge CPU 3.4Ghz
    http://www.novatech.co.uk/products/components/cooling/cpucoolers/rr-212e-16pk-r1.html £29.99 inc vat
    Coolermaster Hyper 212 EVO CPU Cooler
    http://www.dabs.com/products/sapphire-technology-ati-radeon-7870-1000mhz-2gb-pci-express-3-0-hdmi-80T7.html?q=HD%207870&src=16 £259.99
    Sapphire Technology ATI Radeon 7870 1000MHz 2GB PCI-Express 3.0 HDMI
    or...
    http://www.aria.co.uk/Products/Components/Graphics+Cards+-+AMD/Radeon+HD+7870/Sapphire+Radeon+HD+7870+2048MB+GDDR5+PCI-Express+Graphics+Card+?productId=49169 £262.79 inc. VAT
    Sapphire Radeon HD 7870 2048MB GDDR5 PCI-Express Graphics Card
    http://www.amazon.co.uk/Seagate-Barracuda-7200-12-7200rpm-Internal/dp/B006GAK6EI/ref=sr_1_12?s=computers&ie=UTF8&qid=1334442055&sr=1-12 £72.00
    Seagate Barracuda 7200.12 1TB Hard Drive (7200rpm) SATA 64MB (Internal)
  4. These are great replies - thanks a million.
Build Hard Drives Systems
