Solved
Will a new sound card benefit
So today im planning to go out and buy a new speaker system to replace my 2.1 30W system :P
(http://www.memoryexpress.com/Products/MX30674)
so im wondering if i should stick in a sound card, if it's worth it of course
i have realtek HD audio btw
im looking at a few, but i have no clue what im looking at because i've never worked with audio before lol
http://www.memoryexpress.com/Products/MX33909
http://www.memoryexpress.com/Products/MX40246
18 answers Last reply Best Answer
More about will sound card benefit
  1. Best answer
    The audio card will allow u to play the sound louder, but still cleaner than mobo chip.
    I like these PCIE cards.
    hmm, i think so far the sound has been clean enough for me hehe, so i think i shall stick with the integrated chip
  3. Best answer selected by nna2.
  4. As long as u like it. If its not broken, don't fix it : )
  5. How do you know if the sound is better or worse without hearing it? I bought a Sound Blaster earlier this year and thought it was so much better then Integrated realtek. I was using the card with 2.1 speakers, but used it more with headphones. Anyway, after reading in some forums the dislike of the SB card. I ended up buying an ASUS DX, planning to return the one I didn`t like. Basically, an at home 2 week trial of all my own. Ok, I still have the ASUS DX. This card is just awesome. I believe the sound to be clearer without distortion, background noise, I am overall very pleased with the rich sound of the DX.
    With all that said, I would suggest at least trying a card. I`m willing to bet you too will be pleasantly surprised what you`ve been missing.
  6. Quote:
    bear in mind i never ever use headphones when on my PC, i may buy one when i can afford a mid level one
  7. http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
    Here`s a DG on sale at the egg w/rebate = $20. How much are you looking to spend on speakers? Hmm...consider adding 20 dollars to your speaker purchase.
    Search w/google or elsewhere - ASUS DG review.
  8. With good speakers or headset,
    u can hear separation of instruments that is normally not there.
    I like it loud and clear. My friend is a DJ,
    so sometimes I get to listen through really good headset,
    that I would never buy, because of the $$$.
  9. Quote:
    i cannot view american newegg links anymore sorry lol
    they are selling $220 1000W home theatre systems nearby, but i find that to be way overkill for what im doing
    ok, i only currently have around 140 to play with so i think im gonna hold off on that since it's not nessicary to have a sound card
  11. Ok, i`m done here and moving on, but couldn`t help but notice that I just linked a card OP had already found. sorry about that, but it is a decent entry level card - yes, better than integrated. While I own the DX, a friend from work went with the DG and it sounds great.
  12. Quote:
    i wasn't trying to be offensive btw, i clicked on the canadian newegg link and it will now redirect me to the canadian site automatically
  13. SSD can give u some pleasure too : ))
    Unless u have one already.
    i do, 320 series from intel :)
  15. So u know than, ....
  16. hmm, i guess one that isnt limited by SATA 3GB would be nice too....
  17. well i bought them, the bass is fantastic, had a 2 hour long Company of Heroes match to test em out, they sound fantastic
    when i went into the store i was told this about a sound card
    Quote:
    a 20 dollar sound card will have no benefit over your integrated sound card, to get any benefit you would have to spend around 100 dollars
    so there seems to be tons of debate over this subject lol
    That's because sound quality is so subjective but, for the most part I agree with the store.
    Although I would probably add: after you spend $100 or more on a better sound card you would also now want to upgrade your speakers or headphones to take advantage of the sound card.
    Your speakers and your on board sound are probably a pretty good match.
Sound Cards Speakers Audio Components Product
