Solved
New pc build problem
I just got:
ASRock z68 extreme3 gen 3
i5 2500k
8gb corsair vengance 1600 1.5v
chiefmax 750w psu
gigabyte gtx560ti 448
the computer turns on runs sounds like it booting from the hdd but no display
tried removing the video card and tested the monitor still nothing double checked all conectors too
there are no error codes
any thoughts?
5 answers Last reply Best Answer
More about build problem
  1. Is it possible to connect a motherboard speaker (try taking it to your local hardware shop) and get the beep codes? Then, just google the beep codes for your motherboard.
  2. Speaker is hooked up, no codes....
    im thinking the psu is bad... my 3.0v feeds are 1.5v im hoping no damage to the mobo. i ordered a new psu
  3. Good luck!
  4. Best answer
    While never a bad idea to upgrade your PSU try this also.
    Remove all ram. Disconnect HDD, CD/drive, GPU (just disconnect these parts don't actually take them out except for the card). Turn on PC. If still no beeps your mobo may be DOA. It happens with the best of motherboards.
  5. Best answer selected by soch330.
Homebuilt Systems
