Closed
Nokia 6210 security code problem
Archived from groups: alt.cellular.nokia (More info?)
Dear all,
I've bought a new mobile phone and I want to give my old Orange Nokia
6210e to my girlfriend who has a really old Virgin mobile. My old phone
was locked to Orange so I unlocked it by following the instructions at:
http://www.unlockme.co.uk/dct3free.html
When I put the Virgin SIM in, I get asked for a security code. I tried
the numbers I usually use for these sorts of codes and also the Nokia
default of 12345 (which I found via a Google search), but nothing
worked, so I took the phone to my local mobile shop here in the UK <
http://www.daxx.ws/ >. They said that I'd tried to enter the security
code too many times and the phone was now useless and there's nothing I
can do. Is this true?
Cheers,
Ian
2 answers Last reply
More about nokia 6210 security code problem
  1. Archived from groups: alt.cellular.nokia (More info?)
    Ian Sealy wrote:
    >> Dear all,
    >> phone was locked to Orange so I unlocked it by following the
    >> instructions at:
    >> tried the numbers I usually use for these sorts of codes and also
    >> the Nokia default of 12345 (which I found via a Google search), but
    >> nothing worked, so I took the phone to my local mobile shop here in
    >> the UK < http://www.daxx.ws/ >. They said that I'd tried to enter
    >> the security code too many times and the phone was now useless and
    >> there's nothing I can do. Is this true?
    Nope, all you need is a dude with a data cable and a copy of logomanager to
    read off the security code.
    The "too many times then kaput" story is cos the people in the shop confused
    it with the DCT4 unlocking codes (another story).
    >> Cheers,
    >> Ian
  2. Archived from groups: alt.cellular.nokia (More info?)
    On Wed, 21 Apr 2004 10:20:33 GMT, Ian Sealy
    <ntl-news-nokia@iansealy.com> wrote:
    >Dear all,
    >Cheers,
    >Ian
    It's not the phone that's now useless. You only get so many tries at
    entering the SIM security code then you need the PUK from from the
    service provider to unlock it again. Contact Virgin Customer Services
    and ask them for the PUK code.
Nokia Mobile Phones Security
