Computer boots up, no signal on monitor though.
  • Power Supplies
  • Computers
  • Components
Last response: in Components
July 28, 2012 12:49:14 AM
My Specs - OCZ 650 Watt PSU
Intel Core 2 Quad Q8400 Yorkfield 2.66 GHz
Gigabyte Radeon HD 6770 1 GB GDDR5
4 GB of DDR2 RAM
P5KPL-AM/PS LGA 775 Intel G31 Micro ATX Motherboard
500 GB SATA HD with Windows XP preloaded
DVD-R/CD-R Combo Optical Drive
7 Cooling Fans
I was using the computer (Internet, youtube, etc) and then it had froze up, then the screen had went black. I had rebooted the computer, no luck. Screen was still black. The computer boots up fine, fans, lights etc turn on. Help!
More about : computer boots signal monitor
a c 723 ) Power supply
July 28, 2012 1:07:17 AM
My first suspicion would go against the GPU, can you check in another computer?
m
l
July 28, 2012 1:33:52 AM
Most probably the RAM or GPU. Unplug your RAM and put a new one and see, if you are using like 2x 2GB, and you have 4 slots try putting them in different ways. Permutation!
m
l
