Are my computer parts compatible!
Hello, I have just recently got enough money to buy a computer and whanted to know if any of my choosen part are compatible. I don't know much past the basics when it comes to compatibility. This computer will be used for gaming mostly. Please tell me if the parts I have choosen are any good and give suggestion on other parts if you know any better. My price range is about €1000.Thanks!
Parts:
Case: three hundred black steel atx mid tower
Hard drive: western digital av-gp wd5000audx
Monitor: Acer G235HAbd
Graphics card:  01g-p3-1556-kr geforce gtx 550 ti
Ram: g.skill 4gb 2x2gb 240-pin ddr2
Processor: Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32100
Disc drive: LG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model UH12LS28 OEM LightScribe Support
Fan: Cooler Master Hyper 212 Plus
Motherboard: ASUS P8H77-V LE LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Intel Motherboard
Power supply: CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI
3 answers Last reply
More about computer parts compatible
  1. You need DDR3 RAM for your system. Otherwise it looks good.
    -Wolf sends
  2. Thank you.
  3. Looks fine to me.
    - Edit - If you changed to the DDR3 RAM like the other person said. I would suggest CT51264BA1339.
    The 550 TI is a little on the low end for today's computers.
    If you don't need Blu Ray, you can save a lot of money getting a regular DVD drive (like the one in my Signature Asus DRW-24B1ST) and put that towards getting a better graphics card.
    Also, if you get this PSU instead
    http://tinyurl.com/6fgv5fp
    Then you have a lot more money to spend on a better graphics card too.
    Also, the Hyper 212 is overkill if you are using an i3-2100 processor. You can use the fan that comes in the box for free just fine with that.
    Basically, I just think if you scale back on the overspending on some parts you could afford a better graphics card and you would get better gaming performance that way. I would aim for an ATI HD 6870 or 6950 if you can make it that high.
New Build Computer Compatibility Systems Product
