Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Monitor stuck at resolution
Forum Graphics & Displays : Graphics Cards Monitor stuck at resolution
My monitor says it can go to 1920x1200 but the maximum the windows 7 is giving me is 1600x1200
its also not picking up the monitor as a name but just a generic plug and play the monitor is unfortunately at 26' sonyo and the 1600x1200 makes it looked kinda squished
any way to fix this problem
Reply to freeloader93
Install Drivers for the TV from the SONYO site or search Google.
Also you should be able to change it in your GPUs' settings itself there may be a "Force TV detection" somewhere look around. Also from the GPU control panel you would be able to Force 1920x1200 Resolution or 1080p.
------------------------------ HP Pavillion a819n Desktop: Pentium 4 HT 3.2 GHz | nVidia™ Geforce 6200 PCI 256MB | 2.5GB DDR | Maxtor 200GB | Win XP Pro
If I helped you, Select my post as best answer. I like to feel smart :D
http://www.tomshardware.com/membres/ <---TYPO OMFGASH
Reply to brythespy
There are 1467 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 3 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
