Solved
Will a 750 watt PSU power 2 OC'ed 7950's and an OC'ed i5-2500k?
Just as the Thread reads, will a750 watt PSU power 2 OC'ed 7950's @ 1100/1575 and an OC'ed i5-2500k @ 4.2 ghz?
9 answers Last reply Best Answer
More about will watt power 7950 2500k
  1. Power is enough, if its a good psu and has enough pci-e cables.
  2. What's your model 750W PSU?
  3. Should be plenty as long as its a good brand PSU
  4. Best answer
    Yeah no doubt it will be powerfull enough im getting another 7950 and im running a 6100 and its power hungry :P antec high current gamer pro750w
  5. Basically like everybody else says, if it is a quality 750watt that delivers its promised power it will work fine.
  6. Yep pretty much hell a decent 6990 will run on a 750w
  7. thanks guys for the help, has taken almost 200 dollars off my next purchase
  8. You have not answered which actual unit you are buying.
  9. Best answer selected by unlongo.
Power Supplies Power Intel i5 Components
