Solved
Will this motherboard fit the Cooler Master HAF 932 Advanced??
I'm just wondering if this motherboard will fit this case because in one review somebody said it didn't. Will it fit perfectly with no problem, or will it not, or would I have to get anything additonal?
ASRock Z68 Extreme3 Gen3 LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Thanks for your time.
4 answers Last reply Best Answer
More about will motherboard cooler master advanced
  1. Best answer
    Yes. Both are ATX form factor.
    Absolutely! And that's a great case by the way.
  3. Thank you guys.
  4. Best answer selected by IcyShark.
New Build Cooler Master Motherboards Systems Product
