Overheat issue -- 1.1T-bird.. HELP!!!!!
IM USING SONY VAIO VGN CR353 LAPTOP IT WAS SUDDENLY LOGGING OF I DONT NO THE REASON PLEASE TELL ME
3 answers Last reply
More about overheat issue bird help
  1. Hello allampatiram;
    What are your system temps like?
    Have you cleaned the laptop's cooling system latelyl?
  2. no i dont know
  3. Your specs? @ http://www.sony-asia.com/product/vgn-cr353
    Could just be a corrupt OS, is it blowing very warm air out the cpu vent?
    If you haven't got any personal files on the machine you need, I would do a factory restore from the recovery partition or the set of DVD's you should have made when you first logged on to the system.
    http://www.sony-asia.com/support/faq/317750/product/vgn-cr353
Laptops Overheat Sony Vaio Windows 7
