Shopping Cart
just quick question will i be able to throw all that put all that stuff into this case http://www.mwave.com.au/sku-16011412-Antec_Nine_Hundred_Two_V3_Gaming_Case_-_ATX_Midi_Tower_-_10x_Hard_Drive_Bays_-_8, or is the cas that was selected better?
Corsair Carbide Series 400R Midi-Tower Case - 4x 5.25" & 6x 3.5"/2.5" Hard Drive Bays - 8x Expansion Slots - USB3.0 - Firewire Connector - Steel & Plastic - Black (CC9011011-WW) Yes
http://www.mwave.com.au/sku-16011462-Corsair_Carbide_Series_400R_Midi_Tower_Case_4x_5_25"_&_6x_3_5"_2_5
Samsung SH-222BB/BEBS Internal 22x DVD Burner - SATA - OEM - Black
http://www.mwave.com.au/sku-17040390-Samsung_SH_222BB_BEBS_Internal_22x_DVD_Burner_SATA_OEM_Black
Cooler Master Hyper 212 EVO - 120mm Cooling Fan - Intel Socket LGA2011/1366/1156/1155/775 & AMD Socket FM1/AM3+/AM3/AM2+/AM2 - (LGA2011 with Bracket*) 9 - 36 dBA - 600 – 2,000 RPM (PWM) (RR-212E-20PK-R2) Yes
http://www.mwave.com.au/sku-18020624-Cooler_Master_Hyper_212_EVO_120mm_Cooling_Fan_Intel_Socket_LGA2011_1366_1156_115
Intel Core i5 2500K Unlocked Quad Core Processor - Socket LGA1155 - 3.3GHz (Turbo Boost @ 3.7GHz) - 4x 256KB L2 & 6MB L3 Cache - Intel HD Graphics - Sandy Bridge - 32nm - TDP 95W - Fan - Retail Box (BX80623I52500K) Yes
http://www.mwave.com.au/sku-19010218-Intel_Core_i5_2500K_Unlocked_Quad_Core_Processor_Socket_LGA1155_3_3GHz_(Turbo_Bo
Western Digital WD Caviar Blue 3.5" 1TB SATA 6.0Gb/s 7200RPM 32MB HDD (WD10EALX) Yes
http://www.mwave.com.au/sku-22040424-Western_Digital_WD_Caviar_Blue_3_5"_1TB_SATA_6_0Gb_s_7200RPM_32MB_HDD_(WD10
ASUS P8Z77-V LX Motherboard - Intel Z77 Chipset - Socket LGA1155 - 4x DIMM DDR3 - 1x PCIe 3.0/2.0 x16, 1x PCIe 2.0 x16, 2x PCIe 2.0 x1 & 3x PCI - AMD CrossFireX - 1x DVI, 1x HDMI & 1x D-Sub - 2x SATA3 & 4x SATA2 - RAID - Up to 10x USB2.0 & 4x USB3.0 Ports - Gigabit LAN - 8Ch HD Audio - ATX Yes
http://www.mwave.com.au/sku-28023716-ASUS_P8Z77_V_LX_Motherboard_Intel_Z77_Chipset_Socket_LGA1155_4x_DIMM_DDR3_1x_PCI
Corsair TX-650 V2 650W Enthusiast Series Power Supply - ATX12V v2.31 & EPS12V v2.92 - 80+ BRONZE Certified - 140mm Cooling Fan (CMPSU-650TXv2) Yes
http://www.mwave.com.au/sku-34040736-Corsair_TX_650_V2_650W_Enthusiast_Series_Power_Supply_ATX12V_v2_31_&_EPS12V_
Corsair XMS3 8GB(2x 4GB) Memory Kit - DDR3-1600MHz / PC3-12800 - CL9 - Unbuffered - DIMM (CMX8GX3M2B1600C9) Yes
http://www.mwave.com.au/sku-37140937-Corsair_XMS3_8GB(2x_4GB)_Memory_Kit_DDR3_1600MHz_PC3_12800_CL9_Unbuffered_DIMM_(
Microsoft Windows 7 Home Premium - SP1 - 64-Bit - DVD - Single Pack - OEM (GFC-02050) Yes
http://www.mwave.com.au/sku-39090362-Microsoft_Windows_7_Home_Premium_SP1_64_Bit_DVD_Single_Pack_OEM_(GFC_02050)
Sapphire AMD Radeon HD 7870 GHZ Overclock Edition Video Card - GDDR5 2048MB 256-Bit - 1050 / 5000MHz Clocks - 1x DVI, 2x Mini DisplayPort & 1x HDMI - AMD HD3D - AMD Eyefinity - CrossFireX - DirectX 11 (11199-03-41G) Yes
http://www.mwave.com.au/shoppingcart.asp?CartID=mAU@JULO6XVR42IWFIGOQZFGMTPBLXCPLEZ6658YTG199KNOJZ
Sub Total Inc GST: $1,309.97
