nekulturny said:
Of course theres better CPUs out there than a 965 BE. Problem is, they cost more, and for what you're wanting to do with it, the extra cost doesn't really add anything to usable performance. From the AMD market, a Phenom II is going to be the most ideal choice.
On the Intel side of things, I don't recommend an i3 if an i5 exceeds the budget (buy in price for an i5 Sandy Bridge's range from $180-220) I can say that between my significant other's rig (which has an i5), theres no noticeable difference between our systems playing games, and his CPU cost more than mine.
Most games on the market right now do not use more than 2 cores, thus, the i3 performs much the same as the similarly priced quad core 965 BE in gaming, but the 965 BE beats it just about everything that uses more than 2 cores. This would include things such as multitasking, video editing, photoshopping, and eventually games as time goes by.
AMD's most line of CPUs the FX aka Bulldozer have a very Jeckel and Hyde performance ratio, the 965 is a better choice overall, however if you're friend likes big numbers, FX-4100 is capable of heavy overclocking, which makes it a nice little toy to play with I suppose. But its in the same boat with the i3, its not a true quad core, its a dual core that pretends to be a quad.
Back to the XP thing, the problem is, reusing XP just holds the whole system back, all CPUs are 64 bit these days, using a 32 bit OS is just kinda silly, especially when you can get Windows7 and still stay in his budget. As far as RAM usage, its not very hard to use 4 gigs of RAM these days, 16GB like my rig has is massive overkill for a gaming system, 8GB is the sweet spot.
I'm using 4.38GB atm and I don't even have that much going on in my system.
Ok so far this is what I have:
CPU - AMD 965 BE CPU
Computer Case - COOLER MASTER HAF 912
Power Supply - CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Heatsink - COOLER MASTER Hyper 212 Plus (Or just the stock cooler Not sure yet)
CD/DVD Burner - LITE-ON Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model iHDS118-04 - OEM
Thermal Paste - Artic Silver MX4 (had good temps with this for $10.00 in the past before)
Video Card - HIS H687FN1GD Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
That just leaves what mobo, ram and hdd. Should he use a solid state drive or just regular hdd?
Motherboard - ?
RAM - ?
Harddisk Drive - ?
