Hey Guys,
Looking to buy at z77 Sabertooth 1155pin mobo with the i7-3770k CPU.
However, down the track, i am looking to overclock (when i get more research and information done as i will be a newb in doing it)
So with that said, ive had a looking at afew cooling solutions.
I have a Corsair 600t Graphite case, and was thinking either using
- corsair h60 or h80, however, i dont know which one will be better?
Remember im not the best at o/c so i probably wont be able to max out my clock, however i am aware apparently the 3770k runs a little hotter?
Any suggestions will help me alot in deciding which coolant can be used on that mobo and weather they are good choices or not?
Also i have a 850w Corsair TX PowerSup, should be enough to get this thing working? im running sli 560's CD drive, ssd and 2tb drive.
Thanks in advance!
Thanks in advance!
