Upgrade existing build, or start fresh?
Hello all, my existing specs are:
MB: Gigabyte GA-P35-DS3R
CPU: Core 2 duo E6300
2 gig DDR2
GC: Ati Radeon 2600xt
HDD: 2 320g
xp home
I built this possibly four or five years ago as an HTPC but since then hasnt been upgraded as i havnt had the need. I now wish to enter the world of blue ray and full hd output to larger tv, but would also like to dabble in a little gaming,
So my question is as the rig is primarily HTPC is it worth keeping the existing mobo and cpu and upgrading with better graphics card and more ram, or gutting the case and starting again?
Thankyou for your time. :hello:
5 answers Last reply
More about upgrade existing build start fresh
  1. for an HTPC just add a graphics card
  2. I think it would be more cost effective to scrap and rebuild. DDR2 is now more expensive than higher capacity DDR3. So that hits the price. You'll need more RAM to dabble with a little gaming.
    For an HTPC, Llano is the way to go. Windows7 to pair with it would be ideal, you don't need a stand alone graphics card, however you can add a cheap one to give it a little extra boost, although again its not necessary.
    Motherboard- $65
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131813
    CPU + Graphics- $140
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819106001
    RAM- $47 8GB (4GB*2)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
    Power- $45
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
    Windows 7 $100- http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
    Total: $397
    Note: This price doesn't include a case, CD/DVD drive nor a hard drive (this figure assumes you reuse these.)
  3. why would a media player need even 2 gig of RAM ?
  4. He said he wanted to play games with it too. 2 Gigs of RAM and Windows XP kinda hinders that especially considering the llano can handle modern games.
    My mother has an old computer that had 2 gigs of DDR2 RAM with Vista, that thing could barely handle her dumb farmville til she had me come over and stick 4gigs in it.
    Not only media player, but hell Netflix streaming can overwhelm 2 gigs.
    2 gig DDR2
    HDD: 2 320g
    xp home
    specs apart from video card are fine for that purpose if your hdd isnt short on space the majority of decode for the hd and bluray is done on the gpu with minimal cpu usage get a 6 or 7 series amd/ati, near base model will be fine and this will cover you for 3d bluray (tv /software dependant of course) aswell so long as you dont wanna double it as a games machine its fine. i have an amd athlonx2 4200+ (like 2 or 3 yrs older than your e6300 and it does full hd and bluray fine i cant vouch for 3d cos i dont have a 3d tv but it should be technically possible. i only have 1 gig of ram in it too and the only effect that seems to have is that its a bit slow sorting my movie and music collection ( its pretty big) dont let anyone say u need a new rig for a htpc. gaming is hard to say depends on the game bf3 requirements are alot higher than starcraft.
Homebuilt Systems Product
