So it's getting time to upgrade from my 5-year old Q6600 build to a new one.
Approximate Purchase Date: As soon as I am confident about the new build
Budget Range: €600
System Usage from Most to Least Important: Watching HD movies/series, moderate gaming, Photoshop/InDesign productivity, surfing
Parts Not Required:
Case: Cooler Master Centurion 5, Black, silver
PSU: Zalman ZM500-HP, 500 Watt, Retail
HDD: 2x Samsung Spinpoint P120, 250 GB, 7200 RPM, 8 MB, SATA II
DVD-RW: Samsung SH-S203B,OEM, Black, Serial ATA150
Preferred Website for Parts: www.azerty.nl
Country: Netherlands
Parts Preferences: I have had some trouble with AsRock mobo's in the past, so I try to avoid those. Has been years though so perhaps it's silly
Overclocking: No, not seriously anyway
SLI or Crossfire: No
Monitor Resolution: 1920x1080 (PC) and 1368x768 (TV)
Additional Comments: I would like a quiet PC. And one that is quick and snappy in everyday use.
Currently selected parts:
CPU: Intel Core i5 2400 / 3.1 GHz - LGA1155
Motherboard: Gigabyte GA-Z68X-UD3H-B3
Memory: Corsair Vengeance 8 GB PC3 12800
SSD: OCZ Vertex 3 120GB
Graphics Card: XFX Radeon HD6870
My shopping cart: http://azerty.nl/winkelmandje/winkelmandje/?legen=1&product%5B405088%5D=1&product%5B363680%5D=1&product%5B361602%5D=1&product%5B436843%5D=1&product%5B388711%5D=1
My questions:
1. Are my old parts still good? I assume everything will fit just fine in my case, but am I pushing my PSU and HDD's towards the end of their lives yet? They are just over 5 years old now.
2. My gaming is very limited, maybe a couple of hours a week. I just like to play some single-player modi of new titles. I would like to be able to play Crysis 3 when it comes out for example. Ultra settings are not required, I want fluid gameplay on medium - high settings on 1920x1080. That goes for all games. Is the Radeon HD6870 sufficient? Is it overkill perhaps?
3. I stated I don't plan on overclocking because I always believed it was more for fun and bragging than actual day-to-day performance gain and it shortens the life of components. I don't upgrade often so durability is important. If it really does benefit to overclock how will that affect long term durability? I might be willing to go for the 2500K and aftermarket cooler if durability is not compromised.
4. It the motherboard more than I need if I stick with the 2400 and won't overclock? Is it good enough if I do go for overclocking with the 2500K? Same goes for the memory.
5. Any other input you might have!
Many thanks in advance for your time and effort!
Budget Range: €600
Parts Not Required:
My questions:
