[Solved] Best Sound Card and Speaker Combo?
my cpu have no sound
1 answer Last reply
More about solved sound card speaker combo
  1. Generally the cpu doesn't have sound , the sound is from the motherboard and most modern motherboards today have built in sound. If you look at the rear of the computer you will see a series of colored ports and those are the sound connections.
    A lot of speakers today have a usb connection to connect directly to the motherboards sound chip.
Sound Cards Speakers CPUs Components
