Okay here goes the noobiest question ever asked... How do I connect a molex like the one in this pictcure to my psu or mobo? I have only used the 2-3 pin fan connectors.
http://www.amazon.co.uk/Evercool-SB-F1-slot-system-exhaust/dp/B004ZSC0XS/ref=cm_cr_pr_product_top
Do I just take the cable from my PSU and plug it into that? The one with similar connectors that is... it's just when I try it seems to need a lot of force etc. and I don't wanna break something.
Also that cooler will it be good enough to cool my 550ti if I remove its current fan? (The fan blades are broken) It has only 4 blades left so is really noisy.
If it is good enough should I leave the heatsink on the GPU (I'm pretty sure I should)
