G
Guest
Guest
Archived from groups: alt.games.video.xbox (More info?)
I have a 36" Toshiba Cinema Series HDTV (model #CN36X81) hooked up to
the XBox console. It is a picture tube style TV - not a rear projection
or LCD/plasma style. I purchased the High-Def upgrade pack so that I
have component video connections to the Toshiba and 5.1 surround into my
Denon receiver.
I have been having problems playing regular games (non-HDTV format) on
the Toshiba. During the game, the screen flickers bright pink or purple
and then turns black. The game is still running because I can hear the
sound through the receiver. In order to reset the TV, I need to power
off, unplug all of the component inputs (I have one set for HD
satellite, and share one set of inputs between a DVD player and XBox) ,
plug in the satellite and DVD, power up the satellite and DVD to get a
working HD picture, after which the TV resets so that you can view the
other inputs (Cable, Video 1, Video 2 and Video 3).
I also tried to run the non-HD games (Voodoo Vince, Mech-Assault 2,
Splinter Cell Chaos Theory) using the standard XBox setup into the
composite inputs (ie red, white and yellow inputs) into Video 1 or Video
2 on the Toshiba and unplug the component inputs from the XBox which
aren't being used. Same problem - the TV flashed purple about 10 minutes
into playing the game and I had to go through the entire "reset"
procedure.
I then tried plugging in the satellite and DVD into the component
inputs, having both on and running during gameplay, and play XBox
through composite Video 2 inputs. This worked better with only one black
screen over a two hour period. To reset the TV, I was able to simply
turn the TV off and on again.
Playing Halo 2 using the HD upgrade pack and component inputs doesn't
seem to cause any problems.
Has anyone had similar problems??? It sounds to me like a hardware
problem within the Toshiba.
Denon receiver.
procedure.
