Help me pick a new graphics card
APPROXIMATE PURCHASE DATE: After I get some advice on what to buy, ill buy.
USAGE FROM MOST TO LEAST IMPORTANT: Gaming - I box often in WoW and I'm preparing for Copernicus
CURRENT GPU AND POWER SUPPLY: EVGA 560 ti superclocked, Corsair 750tx
OTHER RELEVANT SYSTEM SPECS: intel i5-2500k and Asus P8P67 Pro mb
PREFERRED WEBSITE(S) FOR PARTS:I usually shop at newegg or microcenter
PARTS PREFERENCES: NVIDIA
OVERCLOCKING: No, probably not
SLI OR CROSSFIRE: If there is room, yes
MONITOR RESOLUTION:currently 1920x1080
ADDITIONAL COMMENTS: The best bang for my buck, without crappy display driver crashes and preferably something that is tried and true.
Budget - $500 max for a single card -- or $600 for two
8 answers Last reply
More about help pick graphics card
  1. Well you can buy this card.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127567
    but since you already have a 560 ti i would buy another one (equal) and do SLI, the 750tx corsair can handle it, and at the same time looks like your motherboard is not SLI compatible (why did you bought Crossfire motherboard, to user Nvidia cards?) so or you get a 580, or you also change the motherboard.
  2. get this build
    cooler master haf x case
    p8h67 mobo
    intel i5 2500k cpu
    cooler master hyper 212 evo cpu cooler
    g skills ripjaws x series 8g ram
    nvidia geforce 560 ti superclocked v-card
    western digital caviar blue 1tb hard drive
    sony 24x optical drive
    rosewill capstone-550 80 plus gold psu
    buy parts from newegg
  3. yeah go ahead an get another 560 ti
  4. Sorry i'm mistaken about the MOBO, yes you can go for SLI, i recommend you add another 560 ti
  5. honestly i coulda swore it said SLI ready on the box...
  6. OK so the reason i want a new video card/cards is because the 560ti has caused me nothing but problems ( display driver crashing) so I wanted to get away from the 560.
    Ive tried everything that has been suggested to fix it, even a clean windows install. So im just gonna get a different card
    Plus there will be a new MMO coming out here and I want to be able to box with max settings s, I want something powful!
  7. xtremegamer2da-max said:
    get this build
    p8h67 mobo
    intel i5 2500k cpu
    I dont want to get a brand new build, I just built this one last year and its great minus the crappy video card problems. After troubleshooting and reading tons of forums, i'm not the only one having the issues.
    What seemed to have stopped it (havent had a crash since the change) was upping the voltage to 1.150
    at any rate, i might get another 560ti if it doesnt crash. I'll give it a couple weeks but if it does well thats why im here. TO get some advice on what to get.
    Also wouldnt mind going up to 16gb of ram
Graphics Cards Graphics Product
