Hello,
This is my first post, so sorry if it is long; I've tried to find a way to get it all out simply, but maybe I'm just too new at this. I've got a budget of $1000 total, including my recent purchase of Win7 Pro. Despite the fact that I'm nervous about it, I'm taking the plunge and building my next (first) machine. I could really use some advice on choosing components, as well as whether or not I can/should try to reuse some of the parts from my last computer. While most of the parts were original to the machine, the HDD was a replacement drive and was still working just fine. Here are the specs on my previous machine, a Gateway GT5228 (October '06):
OS: Windows XP Media Center
CPU: AMD Athlon 64 X2 4200+ Processor, 2.2 Ghz 2x512KB L2 Cache 2000MhHz System Bus
Motherboard: FIC K2BC51 Motherboard with NVIDIA GeForce 6100 Chipset (BTX)
HDD: 640GB WD Caviar Black 7200rpm drive (installed Dec. '09)
PSU: Bestec 300W
Memory: (2) 1GB DDR2
Optical Drive: DVD +/-RW Multi-format Double Layer
Card Reader: 9-in-1 Card Reader
Monitor: Samsung SyncMaster 192N (19” LCD)
Speakers: Klipsch w/subwoofer
Case: Gateway supplied
This was our only computer for a long time and it served many purposes. It was a service plan replacement for an HP customized to order (CTO) gaming machine from Best Buy that lost a motherboard numerous times. Recently, the Gateway lost its motherboard, too, and knowing that the PSU was probably part of the problem in both machines, the two things I am most concerned about with my build are a great and reliable MOBO and PSU. In fact, that's my motivation for building – I want control over those two things out of the gate. I don't want to spend a fortune on them, but I do want something decent and will sacrifice a little somewhere else if necessary so those two pieces can function properly. I've checked out the recent system builds and have been checking other builds, and frankly, I'm going a little insane with it all. Here's what I've got:
Approximate Purchase Date: April-May (as soon as the husband finishes work in my office)
Budget Range: $1000 Before Rebates is preferable, After is acceptable provided total isn't over $1000, including OS purchased last week ($120)
System Usage from Most to Least Important: Office programs, surfing the internet (incl. watching shows online), photo editing, music listening, potentially HD video editing (got a new Canon Vixia for Christmas for home movies), potential gaming (husband has some older games and might be inclined toward newer ones if the computer was capable), occasional use of Solidworks, potentially CAD software in the future (not a necessity, yet).
Parts Not Required: OS, Monitor (but it needs a VGA connection), Possibly HDD, possibly DVD +/- RW, possibly 9-1 card reader, possibly GPU.
Preferred Website(s) for Parts: newegg.com, maybe Amazon (I have Prime)
Country: USA
Parts Preferences: No mini-towers, full or mid (as long as a decent MOBO will fit); MOBO with onboard graphics might be helpful; Intel Sandy Bridge i3/i5/i7
Overclocking: No (don't know how)
SLI or Crossfire: No (can't imagine I'll need it)
Monitor Resolution: Can't remember what I was running on the desktop
Additional Comments: Bling isn't required. Quiet would be nice but silent isn't a necessity. The biggest road block is that I'm not sure if I can get by with an i3-2100 or if I should spend the extra and get an i5-2500K or maybe even an i7-2600K.
This is what I'm thinking:
OS: Windows 7 Pro (already purchased on sale at Newegg, $120)
CPU: Intel Core i5-2500K
Motherboard: ?? Possible options:
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
or
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
HDD: REUSE 640GB WD Caviar Black 7200rpm drive
or
SSD for OS and reuse the WD for storage (never really used two drives, though, so a little wary)
PSU: ?? Adequate and reliable are the only requirements
Memory: min 8GB (the Gskill in the Newegg build looked pretty good)
GPU: ?? Will I need one? I've got this one that may or may not work; hard to say if it actually failed or if the problem was with the MOBO. If I can live without for now and add one in later, that might be best.
Optical Drive: REUSE DVD +/-RW Multi-format Double Layer (maybe add a BluRay writer later)
Card Reader: REUSE 9-in-1 Card Reader (for now, but I'd like to get an SDHC reader later)
Monitor: REUSE Samsung SyncMaster 192N (in great shape, despite purchase in '03)
Speakers: Klipsch w/subwoofer (if they still work; if not, I'll just get something inexpensive)
Case: ?? Balance between big enough to fit everything (and maybe some upgrades) and not huge
Phew, that was a lengthy post. I've spent a week trying to make this concise, but where I'm at, it's just difficult. Any help is greatly appreciated.
PSU: Bestec 300W
Country: USA
or
or
