I'm now running an Athlon 850/Asus A7V133/256MB of SDRAM (PC133 that needed to be run at 100MHz?). I have a 40X CD-Rom, a HP CD-burner, 2 WD HD's, Diamond Stealth II 2d/3d card, Voodoo2 3d card, and Creative SB Live Value. This is all running off of my 235 watt AOpen ATX case/power supply.
Things seem to be stable right now. I've had problems since upgrading from a Celeron, but I think that was the whole memory issue. I've ordered a GeForce2 GTS 32MB to replace the Diamond card. Unfortunately, my Voodoo2 doesn't seem to work as well with the Athlon, but that's another story.
So, I have these spare parts to build another system...just need a case. My thought was to buy a 300W case for my current system and put the old stuff in my current case. But I like this case...it works well(so far). And it's not easy finding cases that I like. So...I don't want to change this one if I don't have to. Thanks...
Domm
