PLEASE HELP Can my System be okay in this case??? please help
Okay so I really want the nzxt gun metal but it's only available in the 410 series which is a mid tower not a full tower :(
So I need to know will my system be okay in that case. I mean with good enough cooling without everything packed together frying each other.
This is my system;
i7 3770k
Dual 670 sli
Coolermaster v6 or v8
8gb cosair
120gb cosair gt
1tb western digital
850w cooler master
Please help I need an answer to choose between the two.
Or if any of you know any Phantom full tower paint mods for sale please please please tell me :)
NC
5 answers Last reply
More about please system case help
  1. if the motherboard is ATX your fine
  2. Fitting all of your parts into a NZXT 410 will be no problem. Nice choice in cases by the way.
    What about cooling and upgradeability will anything overheat???
    i doubt it, i was running a 6870+overclocked phenom II in a small case with 1 60MM exhaust fan, and i had no issues with it
    A mid tower case will have plenty of room for parts, and as for cooling, the 410 has plenty of vents for fans so heat should not be a problem.
Power Supplies Cases Cooling Components
