Hello I was looking at some pic & I come across on something I like here is the Case
Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811112287
I got a Question on this Photo the link under will it come with that thing on the case where you can install 2 fans?? or do you have to buy this separate?
http://www.overclock.net/gallery/image/view/album/740523/id/983309/sort/display_order
