Double checking wattage help.
Last response: in Components
August 1, 2012 12:37:01 AM
Hello im buying a new psu and GFX card next week and i need to double check if I am buying the correct wattage i did the calculator thing but i feel like I am still unsure so here are the links any help is thanked :D  :
My Pc: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02...
Psu: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GFX card: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
a c 164 ) Power supply
August 1, 2012 12:41:53 AM
you will be around 300w with that set up while gaming, a solid 500w unit will be fine for you
m
l
August 1, 2012 12:49:21 AM
Thank You I was worred it wouldnt be enough.
m
l
Anonymous
a b ) Power supply
August 1, 2012 12:56:03 AM
even this will work
CORSAIR Builder Series CX430 V2 $44.99
but i am not a big fan of having to use a molex/6 pin adapter. go with rolli59 suggestion
m
l
August 1, 2012 1:21:27 AM
I perfer the one i picked because its modular and my interrior does not have alot of room so i need organization but thankyou for the recommendations as well as the help on figuring out the wattage.
m
l
August 1, 2012 1:28:48 AM
that silverstone is a good PSU and will work well for you. another PSU option for you would be this seasonic which is also modular, has more 12v power (powers your CPU & GPU) 40a to to the silverstone's 34a, has a better warranty 5yr vs 1yr, is rated to 50c to the silverstone's 40c and best of all costs less. Not that that silverstone can't do the job but i would personally get the seasonic for the reasons above.
m
l
Anonymous
a b ) Power supply
August 1, 2012 1:40:58 AM
fixed that for ya :)
m
l
August 1, 2012 1:42:25 AM
thanks
m
l
August 1, 2012 1:56:51 AM
wow thanks i like the seasonic! will defenitly be thinking about which to buy.
m
l
a c 701 ) Power supply
August 1, 2012 11:35:55 AM
That deal on the Seasonic is the best one on modular at the moment.
m
l
August 7, 2012 8:53:28 PM
Hello im back and i purchased the seasonic and the 6870 will receive them on Friday. Hope it turns out well :D
m
l
