CPU= Intel Core i5 2500K CPU
MOBO= ASUS P8Z68-V/GEN3
SSD= Patriot Pyro 120GB
PSU= CORSAIR Builder Series CX600 V2 600W
ODD= ASUS 24X DVD Burner
RAM= CORSAIR Vengeance 16GB
So at first nothing started up except for a light on the motherboard. That was because I had something plugged in the wrong place.
Now when I turn the power on, The PSU runs, the Case fan, CPU fan, all lights on the Mobo light up, ODD works for 10 sec...then the CPU LED light flashes and the computer reboots. After that it runs continuously, but my screen doesn't show any BIOS.
I've tried reconnecting plugs and using different amounts of RAM(4,8,16) in the correct channels to no prevail.
***UPDATE***
It was faulty ram, got a new set and it will start up now in BIOS mode. But now I'm having more issues.
Ok so now I got into BIOS mode tried installing Windows XP and as it says "Windows is now setting up.." at the end, a blue screen with an error comes up.
It tells me a problem has happened, to check my computer for viruses, remove any newly installed hard-drive or hard-drive controllers.
Check my hard drive to make sure it's properly configured and terminated.(unsure what it means by that)
Run CHKDSK /F to check for hard-drive corruption and then restart my computer.
(tried this, nothing)
Techincal Information:
*** STOP: 0x00000078 (0xF780663C, 0xC0000034, 0x000000000, 0x00000000)
This is way over my head now, any help?
Only thing I can think of is a faulty SSD, but hoping not
***UPDATE***
