Hello,
To Start, here are my computer specs:
AMD Phenom II X6 1090T with the stock cooling system
VGA GTX470
2x 4 MB corsair RAM (I believe)
MSI NF750 Motherboard (old)
AsRock 970 Etreme3 (new)
A few days ago my computer turned itself off and would not turn itself on. I diagnosed (what I believed to be the problem) as the motherboard. I picked up a new motherboard that seemed like it would work (the 970 Extreme3) and basically just switched over all all the components to the new motherboard. The computer started just fine, but after about an hour or two shut off. I checked the CPU temp to see if it was overheating and it was at a solid 115 C. I left the computer for awhile and came back and watched the temp steadily climb from 40 C to about 100 before I decided to turn it off before it did itself anymore damage.
I was wondering what could be causing my CPU to overheat? Was the CPU in the first place that ruined my first motherboard?
VGA GTX470
