Solved
SYSTEM TURNS ON UNTIL I PLUG IN FANS
Hey Guys ! I just put together my new system today! It turns on until i plug in the fan hub in my p280 that powers 3 120mm fans.it uses a 4 pin power connector. HELP!
System specs are:
Mobo: Asus P8Z77 VE Plus
CPU: 2600k
Ram:8 GB corsair vengeance
Heatsink:Hyper 212 Evo with push pull set up
GPU: Gigabyte Gtx 670 windforce edition
Psu: 750 watts
Case:Antec p280
SSD:128GB
HDD: 2x 1 tb seagate barracude (Not connected atm)
9 answers Last reply Best Answer
More about system turns plug fans
  1. What PSU brand do you have?
    My guess is one of the fan's is shorting out.
    Corsair
    what should i do :(
  4. aaab said:
    You don't happen to have a multimeter? Can you unplug each individual fan? And test each one, one at a time?
    nope :(
  5. You don't happen to have a multimeter? Can you unplug each individual fan? And test each one, one at a time?
  6. Best answer
    disconnect all fans and let the fan controller/hub connected.. is it boot?
    Did the 4 pin (molex?) connected to other device ? or it only connected to the hub?
    Likely there a short in the hub that make the protection in the psu kick in
  7. Best answer selected by abnormalweeny.
    Even though i fixed the problem before you answered this was indeed the problem
  9. well glad to hear it all good now....
Power Supplies Components
