Closed Solved
Dual monitor setup help
Hey everyone I need help getting my two monitors to work right. I'm using Evga/Nvidia Gtx 275 oc with 2 Dvi inputs. My monitors are Samsung 20.0 multisyc 1680x1050 res. The second one is Dell Ultra sharp 1280x1060 max res. I set up the displays using the Nvidia control panel both displays actually work but not as one display. I can only get them to work as basically two displays at the same time. How can I get them to work as one larger display together?
5 answers Last reply Best Answer
More about dual monitor setup help
  1. Best answer
    You can go to the 'screen resolution' on windows and extend the displays. Each monitor should be at it's native resolutions. Good luck :).
    I've tried that but still wont work!
  3. Allright I've tried everything I think.. Does anybody have any suggestions that could help?
    I would appreciate it!
  4. Best answer selected by hoglan71.
  5. This topic has been closed by Mousemonkey
Nvidia Displays Graphics
