Help with new build
giovi1514
Hello,
I use to build computers many years ago and now I want to get back in to it and build an awesome gaming machine my ideas so far are
CPU: i7 3770k
Gpu: gtx 680
Psu: corsair 1200w psu
Mobo: asus maximums v formula
Ssd: ocz vertex 4 128 GB
Hdd: WD black caviar 2 tb
Ram: 16 GB rip jaw 2133 MHz
Pump: MCP655 pump
Radiator: Aqua computer AMS Airplex Modularity System 360mm
CPU block: XSPC Ray Storm
Gpu block: EK FC680 GTX Full Cover Water block
Fans gentle: typhoon 3000 rpm
Fan controller: Scythe KQ02-BK Kaze Q12 12-Channel Fan Controller
Case + reservoir: my old ones which are big enough and work fine
Anything you would change?
I did a fair bit of research but it is possible I missed something
And is it true that there won’t be a maximums v extreme it is possible I am just mistaken but that is what I have been told
Lieutenant Awesome
212
Damn you have a lot of money to spend on this, haha. Well, I'm pretty sure your PSU is overkill, so you might want to just get something like an 850W one? You could use that money to buy more RAM, you might as well get as much RAM as that board can handle, must be at least 32GB, maybe 64 or something.
