Hello,
I use to build computers many years ago and now I want to get back in to it and build an awesome gaming machine my ideas so far are
CPU: i7 3770k
Gpu: gtx 680
Psu: corsair 1200w psu
Mobo: asus maximums v formula
Ssd: ocz vertex 4 128 GB
Hdd: WD black caviar 2 tb
Ram: 16 GB rip jaw 2133 MHz
Pump: MCP655 pump
Radiator: Aqua computer AMS Airplex Modularity System 360mm
CPU block: XSPC Ray Storm
Gpu block: EK FC680 GTX Full Cover Water block
Fans gentle: typhoon 3000 rpm
Fan controller: Scythe KQ02-BK Kaze Q12 12-Channel Fan Controller
Case + reservoir: my old ones which are big enough and work fine
Anything you would change?
I did a fair bit of research but it is possible I missed something
And is it true that there won’t be a maximums v extreme it is possible I am just mistaken but that is what I have been told
CPU: i7 3770k
Gpu: gtx 680
Pump: MCP655 pump
