Build mini itx please help
hellos i want to build a mini machine for my room and i had think in
Case
AeroCool M40 Cube Computer Case - Micro ATX, LCD Display, 2x 5.25 Bays, 3x 3.5 Bays, 4x Fan Ports, Black
motherboard
F1A75-I DELUXE
Mini-ITX Motherboard with DIGI+ VRM & AMD Radeon™ HD 6000 Series Graphics on A75 platform
processor
AMD AD3870WNGXBOX Unlocked A8-3870K Quad Core 3.0GHz 100W - Socket FM1
video card
Visiontek 900485 Radeon HD 6670 Video Card - 1024MB, GDDR5, PCI-Express 2.0 (x16), 1x DVI, 1x HDMI, 1x VGA, DirectX 11, Single-Slot, Low Profile
would appreciate to help with the power supply and the memories and if you have any suggestions on how I'm putting the pc any suggestions are welcome thanks in advance if someone speaks Spanish better still because my English is not good
8 answers Last reply
More about build mini help
  1. Move this post to the systems thread, then you will get some answers
  2. This topic has been moved from the section Graphics & Displays to section Systems by Mousemonkey
    thanks man i am new
  4. i used Silverstone ST45SF 450W SFX powers supplies in both my mini pc builds
    nice 450watt 80+ bronce
    helps in small form factor cases like the one u chose
    http://www.silverstonetek.com/product.php?pid=253&area=en
    thanks man is correct the items that i pick or you have some recomendations i have 700 and i want the asus motherboard and the micro i think is the best for fm1 socket iam correct???????
  6. this list shows what gpu it can run , upto GTX 680*1 or HD7950*1 , 36amp on the +12 volt rail
    http://www.silverstonetek.com/downloads/PSU/GPU-supportlist.pdf
  7. you have a micro ATX case so you may as well use a m-ATX motherboard . More features and more expansion options at a lower price than a mini-ITX case .
    http://www.thebestcasescenario.com/forum/showthread.php?t=13692
    A modular psu will be essential . You need about 400 watts .
    Always use 80+ bronze [ or better] rated psu's
    thanks man i like the asus itx because it has all that i want i guess? but if you have another opinion it is welcome i trying to build the best posible i have 700 and i dont want the monitor because i use my tv Samsung 46UND7000 and i have a iogear keyboard so i only nedd de machine i would like to keep the chasis or something like cube cases sorryo for my english all help is welcome thanks
Build Systems
