Hi all,
I been using these forums to solve all PC related issues but I am now stumped I hope someone can help me out.
I have a Asus P5Q mother board, Intel Q6600 G0, 4GB DDR2 Ram 333Mhz upgrading to blastix 800mhz (soon).
A few months back I discovered that my idle temps using Real temp and CPUID was between 55-75C massive difference when idle or medium use(stock cooler), I have had the PC for 4 years and wanted to overclock to around 3.0Ghz before I buy a new rig, However today I installed a Arctic cooler freezer 13 pro.
I am pretty sure I applied the artic mx4 compound properly and not too much however the temp is still 65C??? that's using real temp and on CPUID its 58C
the sensor movement is 13 13 14 11.
Please if anyone can advise what to do beacuse I am keen to overclock this PC before I upgrade its been in heavy use for past 4 years so I dont excpet too much. I have two chassis fans one pointing inwards and one outwards back of the computer behind heat sinks.
Sorry if I sound noobish I am a complete amatuer
Thank you.
Thank you.
