System running fine or to hot?
Idonno
694
Like "clutchc" said, "If those are idle temps, I think the CPU is too warm" So are they?
If however your PC is under a heavy load then those temps are very nice. So definitely a little more info is needed.
fussionzz97
55
With about 30 tabs open and minecraft, skype etc open im at those temps, when idle im at around 30
Idonno
694
Then IMO your in good shape! Your CPU's thermal protection doesn't kick in till 100c but I'd feel comfortable as long as your temps don't exceed 80c with an occasional spike under 85c during stress testing. So another wards your temps are fine.
:D
fussionzz97
55
Sweet thanks!
fussionzz97
55
I just cleaned up my computer and reattached everything in fine when i've got no game open im running 30-40C fine as soon as i open up a game im up 80+
http://oi45.tinypic.com/2h6sv0j.jpg
Whats going on here?
Edit: what i did when i cleaned my computer
Took case off, unscrewed Fan+heat sink, cleaned the fan, heatsink and the top of the CPU from dust rescrewed Fan+heatsink pluged cord in , booted and now this problem
Just for clarification, you took the heatsink completely off? If you did, did you reapply new thermal paste? You absolutely NEED to if you didn't (after thoroughly cleaning off the old stuff first).
fussionzz97
55
Ok... i know the problem :( Where could i get new thermal paste from? (Australia, Sydney)
fussionzz97
55
I just purchased the Arctic silver 5 thermal compound. so i just clean the heatsink and CPU top, place some paste onto it and place them together, screw it in and all good?
Yep. Just put a small "pea sized" dot in the center of the CPU heatspreader and don't spread it, just let the cooler spread it when you reinstall it.
fussionzz97
55
Yep watched a few videos to make sure how to do it properly. So this will fix my temperature problems?
clutchc
Ambassador
...and if you are using the stock heatsync/fan from Intel, be sure the pushpins have expanded the white posts and locked behind the board properly. A improperly installed cooler with poor contact to the CPU heat spreader will not transfer heat well.
http://www.pcstats.com/articleview.cfm?articleID=2677
Also, AS5 is quite electrically conductive. Be careful not to get any on the board. I have switched to Arctic MX4 just for that reason. But AS5 is a good TIM, nonetheless.
fussionzz97
55
I have the exact HS, fan. So just putting a pea sized blob of Thermal paste in the center and just squash the heatsink ontop of it and push the pins in is all good?
G
Guest
Guest
What was the temprature in your room when you had these tempratures? beacouse in the end the only information usefull is how much C you are above the ambient temprature in your room with what CPU (Ghz) (volts), cpu cooler, thermal paste.
clutchc
Ambassador
To apply the TIM correctly, follow the Arctic instructions for your processor: http://www.arcticsilver.com/intel_application_method.html#
To correctly install the Intel cooler follow these instructions:
http://www.pcstats.com/articleview.cfm?articleid=2231&page=6
Pay attention to the arrows' orientation on the push-pins before installing.
fussionzz97
55
It's winter down here in Australia and its freezing probly about 20C inside the house
Thanks for the tips and Tutorials. I guess ill get back to you after i install all this
