Which power supply is better for my system?
Power Supplies
- Cougar
Components
Last response: in Components
mykebrian
August 3, 2012 3:08:13 PM
antec 550vp, cougar RS650 or RS550?
my system is
cpu: core i3 2120
motherboard: gigabyte h61m-ds2
graphic card: sapphire hd 6770
here the link to cougar specs:
http://www.cougar-world.com/products/power_supplies/cou...
I don't know the how to compare power supply so please help.
my system is
cpu: core i3 2120
More about : power supply system
mykebrian
August 3, 2012 3:15:22 PM
The Cougar RS650 made the PSU Lemon List I maintain:
http://www.johnnylucky.org/power-supplies/psu-lemon-lis...
Scroll down to the Cougar section and you will see a brief summary of problems with the psu. You can follow the links to a competent technical that uncovered the problems.
m
l
mykebrian
August 3, 2012 3:24:59 PM
Anonymous
a
b
Power supply
August 3, 2012 3:25:59 PM
mykebrian
August 3, 2012 3:27:22 PM
yah corsair tx550 better than antec VP550p (basic) but not cheap
http://www.hardwaresecrets.com/article/Corsair-TX550M-P...
m
l
mykebrian
August 3, 2012 3:29:35 PM
henydiah said:
yah corsair tx550 better than antec VP550p (basic) but not cheaphttp://www.hardwaresecrets.com/article/Corsair-TX550M-P...
can you also compare the corsair tx550 to LITEPOWER 600WATTS?
m
l
Do you mean the Corsair Enthusiast Series, Model CMPSU-550TXM? That model did very well when subjected to rigorous testing and in-depth component analysis:
http://www.johnnylucky.org/power-supplies/psu-recommend...
Scroll down to the Corsair Section where you will find links to 6 competent technical reviews.
m
l
Anonymous
a
b
Power supply
August 3, 2012 3:32:23 PM
mykebrian
August 3, 2012 3:35:39 PM
There are three versions of the Thermaltake Litepower 600 watt power supply. There is no record of any competent technical reviews of those three models. That does not mean mean they are bad power supplies. It just means the models were never subjected to rigorous testing and in-depth analysis. With several thousand psu's available there are quite a few that are not tested.
m
l
Read discussions in other Components categories
