Hi all,
Recently purchased a i7 3770k system from Microcenter. The CPU fan seems annoyingingly loud - so i installed SpeedFan and it seems to be running around 2600-2800rpm constantly, even at idle. The CPU temp reads around 36C.
The stock CPU fan is a CM12V. I was wondering if it should be running this high all the time? SpeedFan won't let me change the speed, I poked around the BIOS and the default setting was set to AUTO, the only other option is MANUAL, but i didn't really see any where to set temp settings and honestly I'm not sure what I'm doing there anyways. I just wanted some advice on if this is a normal situation.
Thanks.
Thanks.
